주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Early 2013 SSD Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, SSD: 5 단계, 이미지 1개 중 1개
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  6. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 6 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
결론
다른 60명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,981 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,656개를 작성함
17가이드 댓글
Where is the left fan in the pic? Please tell me I don't need to remove the fan before doing the replacement.
Ethan - 답글
I see that for all the guides for all the MBP models with solid state storage, the battery is disconnected before the solid state storage is removed. Why?
Traditional hard drives and SSDs don't have to have their batteries disconnected before removing...do they?
Hobowan Kenobi - 답글
You should remove it. It's just good practice when doing anything internal on any laptop.
farleyaustin -
这个ssd的接口是什么呢?我应该购买什么型号的ssd能适配这个,怎么筛选?
lizhao - 답글
Can I update my SSD to 1TB from 512GB? RMBP 2013 Early
FAN Guoxing - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 84
지난 30일: 586
전체 시간: 107,210
