도구
부품
지정된 부품이 없습니다.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
