소개
Fans can be such blowhards, except when they blow out. Use this guide to help you replace a damaged, broken, or faulty right fan.
필요한 것
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
다른 55명이 해당 안내서를 완성하였습니다.
댓글 12개
Great guide! It took me 45 minutes to replace my old and loud right fan. Thanks for the guide!
Installed the new fan but it's not running. Other fan is running. Any ideas?
done! thank you fixit!!!!
