소개
이상한 소리가 들리나요? 소리가 안들리나요? 이 안내서를 사용하여 15" Mid 2015 MacBook Pro Retina의 왼쪽 스피커를 교체하세요.
왼쪽 스피커는 사용 중에는 기기의 왼쪽에, 작업 중에는 오른쪽에 있다는 점에 유의하세요.
필요한 것
스퍼저 또는 핀셋을 사용하여 AirPort 안테나 케이블 세 개를 AirPort 보드의 소켓에서 똑바로 들어 올려 구부려서 방해가 되지 않도록 하세요.
T5 Torx 드라이버를 사용하여 오른쪽 팬을 로직 보드에 고정하는 다음 나사 세 개를 풀어주세요:
숄더 길이가 2.0mm인 5.0mm 나사 한 개
머리가 넓은 4.0mm 나사 한 개
4.4mm 나사 한 개
왼쪽 스피커를 상단 케이스에 고정하는 다음 나사를 풀어주세요:
2.7mm T5 Torx 나사
6.9mm T5 Torx 나사(4.5mm 숄더 포함)
5.6mm T5 Torx 나사
기기를 재조립하려면, 이 단계들을 역순으로 따르세요
다른 77명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 18개
Hi! Such an excellent guide you’ve made. But I wonder, if I want to replace only the speaker, should I disassemble most of the parts or just doing step 41-42? Because I’m too afraid that I’ll break those small wirings and connectors.. while my only problem is the speaker.
Unfortunately, you must disassemble the whole machine - the board is covering a portion of the speaker and therefore it is impossible to remove with the board still on there.
Hi, I just went through replacing the left speaker and the screen. So much more involved to get to the left speaker than changing the screen.
But the replacement speaker is only giving me highs and not bass. Anyone ran into this issue? could it be a faulty speaker? I bought it here on ifixit. I don’t suppose it is from a bad replacement procedure that I could have done. Either the speaker has sound or it doesn’t?
Thanks.
No, have not noticed a decrease in bass from the replacement speaker. (bought used from eBay) Not that you’d want to disassemble everything again but there does seem to be an air intake opening near the end of the long section of the speaker. Perhaps it’s clogged? Also, the shape of the inner speaker is different on the replacement - original is round and the replacement is hexagon, though they both seem to sound the same.
Same. Replaced 2 speakers— one was low sounding, neither any bass. Returned, replaced again, same issue. At wits end.
