주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 1 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 1 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 1 단계, 이미지 3/3
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
    • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  2. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 2 단계, 이미지 2/2
    • Peel the right rubber cover up off the fan and fold it out of the way.
  3. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 3 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 3 단계, 이미지 2/2
    • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
    • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
  4. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 4 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 4 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 4 단계, 이미지 3/3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,852 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 360
