주요 콘텐츠로 건너뛰기
소개
Pre-req for unplugging the battery without removing it.
부품
지정된 부품이 없습니다.
  1. Peel back the sticker covering the battery connector.
    • Peel back the sticker covering the battery connector.
  2. Gently lift each side of the battery connector to pry the connector out of its socket on the logic board. Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board. Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
440,990 평판
안내서 547개 작성하였습니다
iFixit iFixit 회원
Community
137 회원들
안내서 16,708개 작성하였습니다
댓글 2개
So. replacing the battery on this model is quite a lot easier than on previous 15" Retina Macs?
Martin Bergstrom - 답글
Aha, ”battery *connector* replacement". Sorry...
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 956
