주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 2 단계, 이미지 2/2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 3 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 3 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 3 단계, 이미지 3/3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: 4 단계, 이미지 1/1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 5 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 5 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 5 단계, 이미지 3/3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): 6 단계, 이미지 1/1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 7 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 7 단계, 이미지 2/2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 8 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 8 단계, 이미지 2/2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 9 단계, 이미지 1/1
    • Peel the top I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,810 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 99
전체 시간: 8,953
