주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 2 단계, 이미지 2/2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 3 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 3 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 3 단계, 이미지 3/3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Battery Connector: 4 단계, 이미지 1/1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 5 단계, 이미지 1/3 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 5 단계, 이미지 2/3 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 5 단계, 이미지 3/3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Left Fan: 6 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement, Left Fan: 6 단계, 이미지 2/2
    • Peel the left rubber cover up off the fan and fold it out of the way.
  7. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 7 단계, 이미지 1/1
    • Remove the following three screws securing the left fan to the logic board:
    • One 3.6 mm T5 Torx screw with a wide head
    • One 5.0 mm T5 Torx screw with a 2.0 mm long shoulder
    • One 4.4 mm T5 Torx screw
  8. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 8 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 8 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 9 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2015 Left Fan Replacement: 9 단계, 이미지 2/2
    • Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
    • The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
    • Remove the fan.
결론
다른 47명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
503,085 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 2개
First repair job. After 5 years of use my laptop was getting heated quicker than the oven and making that antique modem noises. With 2 screwdrivers and a plastic card to pry the connectors cleaned all the dust inside the case and the fans following the fan replacement guides without any trouble. Huge thanks to Andrew for this very detailed page! Btw, if you intent to reuse the fans, be careful with the connector cables. They are not flexible, they bent easily and might break.
Furkan Karagöz - 답글
Thank you so much - I used this to access and clean (but not replace) the fan.
CCC - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 36
30일 전: 157
전체 시간: 32,111
