주요 콘텐츠로 건너뛰기
MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
필요한 것
  1. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: 1 단계, 이미지 1/3 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: 1 단계, 이미지 2/3 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: 1 단계, 이미지 3/3
    • heat the logo bezel(用吹风机小心的加热LOGO挡板)
    • use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
  2. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: 2 단계, 이미지 1/1
    • Put double-sided tape on the back of the bezel(在新的挡板后面贴上双面胶带)
  3. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: 3 단계, 이미지 1/1
    • Install the bezel 把挡板安装到原来的位置
결론
当重新组装你的设备时,请按照说明的相反顺序进行操作。
다른 13명이 해당 안내서를 완성하였습니다.
n0vem
회원 가입일: 08/26/17
607 평판
안내서 1개 작성함
댓글 60개
I didn't manage to get it off without breaking it so had to order a new one. which was a peal and stick.
mayer - 답글
I don’t understand, when do you need to remove this if it’s not broken already? Are there components underneath that can be replaced/fixed?
Ted -
I have a hairline at the logo baffle if i do not replace it will my screen get harmed?
Please reply ASAP?
Honey - 답글
can u upload the photo, than I can tell u
n0vem -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 79
전체 시간: 36,233
