주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. heat the logo baffle(用吹风机小心的加热LOGO挡板) use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎) use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
    • heat the logo baffle(用吹风机小心的加热LOGO挡板)
    • use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
  2. Put double-sided tape on the back of the baffle(在新的挡板后面贴上双面胶带)
    • Put double-sided tape on the back of the baffle(在新的挡板后面贴上双面胶带)
  3. Install the baffle 把挡板安装到原来的位置
    • Install the baffle 把挡板安装到原来的位置
결론
当重新组装你的设备时,请按照说明的相反顺序进行操作。
다른 10명이 해당 안내서를 완성하였습니다.
n0vem
회원 가입일: 2017년 08월 26일
544 평판
안내서 1개 작성함
I didn't manage to get it off without breaking it so had to order a new one. which was a peal and stick.
mayer - 답글
I don’t understand, when do you need to remove this if it’s not broken already? Are there components underneath that can be replaced/fixed?
Ted -
I have a hairline at the logo baffle if i do not replace it will my screen get harmed?
Please reply ASAP?
Honey - 답글
can u upload the photo, than I can tell u
n0vem -
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 95
30일 전: 425
전체 시간: 28,471
