이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
Mac 전원을 켜고 Terminal/터미널을 시작하세요.
다음 명령을 복사하여 Terminal/터미널에 붙여 넣으세요 (또는 정확히 입력하세요).
sudo nvram AutoBoot=%00
[return]을 누르세요. 관리자 암호 입력 메시지가 나타나면 관리자 암호를 입력하고 [return]을 다시 누르세요. 참고: return 키는 ⏎ 또는 "enter/입력"으로 표시되어 있을 수도 있습니다.
sudo nvram AutoBoot=%03
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle just enough to open a small gap under the lower case.
Slide the corner of an opening pick into the gap you just created underneath the lower case.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
다른 21명이 해당 안내서를 완성하였습니다.
