주요 콘텐츠로 건너뛰기
소개
Use this guide to replace an old or faulty battery. If your battery is swollen, take appropriate precautions.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
    • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
    • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
    • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
    It really depends on how thick the 1.5 mm flathead screwdriver is. I tried a low-cost tool and almost destroyed the screw. So be carefull
    Paul - 답글
    Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
    Peter Payne - 답글
    I agree...
    I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
    remjok - 답글
  3. Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    The screws holding my battery were all worn out since an earlier removal. So instead of ruining them even more I put some saran wrap on the tip of my pentalobe driver and gently unscrewed them.
    magnus - 답글
    I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
    Does anyone know which thread it is and which length?
    alexanderleith - 답글
  4. Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  5. Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. Tilt the battery back enough to access the battery cable connector.
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it as soon as possible.
결론
다른 164명이 해당 안내서를 완성하였습니다.
Walter Galan
665,355 평판
안내서 1,203개 작성하였습니다
댓글 19개
Changing this battery for a friend went as smooth as silk. I've done this many times before so that was no surprise, but now the battery (bought from ifixit) shows only 85% charge even after being left all night to charge, and the charger stopped charging and shows the light on the charger shows green.
What have we done wrong and what do we need to do about it?
Lord Groundhog - 답글
You need to calibrate the new battery. Charge until it won't charge any more. Unplug the computer and leave it until it puts itself to sleep from low battery. Make sure your settings are as low a threshold as possible (3%) I think is the minimum. Then plug it in and charge back to 100%.
Daniel Henry -
Further note: we tried running off the battery, and when it was at 44% tried to recharge it using another charger that we knew was working. The battery indicator says the battery is not charging.
Lord Groundhog - 답글
Hola buenas. necesito comprar una bateria para mi macbook pro 15", de mediados del 2009, en el que la tapa se abre entera. no se que modelo de bateria es, me podriais decir el nombre o referencia que lleva por favor??? me estoy volviendo loca buscando por internet.
Eugenia Padero - 답글
It's possible to be necessary to reset the battery controller SMC.
It's the last step to do
https://support.apple.com/fr-fr/HT201295
https://support.apple.com/en-us/HT201295
jpchagnon - 답글
If the battery is non removable (MacBook Pro from 2009) :
Shut down your Mac.
Unplug the MagSafe or USB-C power adapter from your computer.
Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
Release all keys.
Reconnect the power adapter.
Press the power button again to turn on your Mac.
Si la batterie n’est pas amovible
Éteignez l’ordinateur.
Branchez l’adaptateur secteur MagSafe ou USB-C à une source d’alimentation, ainsi qu’à votre Mac.
À l’aide du clavier intégré, appuyez sur Maj + Contrôle + Option dans la partie gauche du clavier, et appuyez en même temps sur le bouton d’alimentation.
Relâchez toutes les touches, puis appuyez à nouveau sur le bouton d’alimentation pour allumer votre Mac.
jpchagnon - 답글
Attention à la traduction de l’article suivant:
Shut down your Mac.
Release all keys.
Débranchez l’adaptateur secteur MagSafe ou USB-C de votre votre Mac.
Pascal Galliot -
Thanks so much for posting this great, well-written, and well-documented tutorial. Couldn't have done it without you. Probably just made me $2-300. :)
dave_dd - 답글
The battery I received has a pad on the bottom on one end that was not on the original battery. this interfers with the trackpad clicking mechanism. Did they send the wrong battery (it fits otherwise)? Should I remove this pad?
Larry Anovitz - 답글
The instructions for step five are kind of ironic.
Spam Junk - 답글
Angeblich ist der Akku im MacBook Pro 5,4 fest verbaut (geklebt). Wie bekommt man ihn dann heraus?
Thomas Paul - 답글
Thank you very much for the detailed instructions, it helped greatly.
I just replaced my battery and was done in 20 minutes and everything is working fine.
NR - 답글
Greate man Thanks I will follow the guide
Manoj - 답글
Xion Midmklo sdmdl kdodk ?
fghfgjhfg ghjghjf - 답글
Worked fine for me for almost 7 month. Then over sudden the battery was dead. Charging was not possible anymore and MAC-OS indicated, that the battery has to be changed immediatly. When connecting the Charger the green LED went on, fainted and went on again for several times.
SMC-Reset had no effect on my problem. What do you suggest i should do?
ga-z - 답글
I forgot to tell that os is booting fine without any issues but only with the DC charger connected to the system.
ga-z -
This guide worked as written except that the screw holes of new battery were off by a hair. One would need shaved off the plastic inside one of the outer holes or cram the one of screws with force. This issue may very with battery producer.
markjville - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 37
30일 전: 181
전체 시간: 164,677
