소개
Use this guide to replace your MacBook Pro's display assembly.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
이 단계에 사용된 도구:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
I agree...
I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
Does anyone know which thread it is and which length?
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Pull the camera cable away from its socket on the logic board.
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
Lift the Bluetooth board/cable retainer assembly out of the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 3개
Will a 2010 A1286 Display assembly fit a 2009 A1286 Macbook Pro?
I greatly appreciated your comment in Step 8 saying: “Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket“.
My problem was that I had an old Macbook Pro whose camera cable was out of its socket and I could not get it in because this piece of plastic was in the way. I had no idea what it was. It was not clear to me if it was an IC or some other important component. Your comment clarified what it was and its purpose.
Pushing down on it at one end did not achieve anything, so I have just lifted it up and off the board using a small scalpel blade.
I will use some tape to hold the cable connector in its socket.
Thank you
