이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace a faulty fan to keep CPU temperatures down.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 한 개
One note of caution, beware of surprises. I had a problem with my Macbook Pro last summer and took it to Apple for repair and it turned out to be a settings issue and nothing mechanical but in the discovery process it was gutted and re-assembled. When it developed a fan problem last month I ordered a fan from Ifixit and went through the repair process. After removing the base plate it was then time to remove the fan using a Torx #6 screwdriver here is where the surprise was. Apple had substituted one of the three screws with a different type. Luckily I was able to find a screwdriver that worked.
So be be prepared for a possible surprise.
