주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement
필요한 것
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement, Lower Case: 1 단계, 이미지 1/1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement: 2 단계, 이미지 1/1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
결론
다른 26명이 해당 안내서를 완성하였습니다.
Walter Galan
694,644 평판
안내서 1,203개 작성하였습니다
댓글 한 개
These two little plastic clamps on the upper case that snap on/off the lower case broke. I was looking through the store for replacements but I couldn't find any. Does anyone know where I can get these?
hmalissa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 15
전체 시간: 15,691
