주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Early 2011 Logic Board Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  2. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
    • Lift the right fan out of its opening in the logic board.
  3. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 3 단계, 이미지 1/1
    • Pull the camera cable out of its socket on the logic board.
    • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
  4. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 4 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  5. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 5 단계, 이미지 1/1
    • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
  6. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 6 단계, 이미지 1/1
    • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
  7. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 7 단계, 이미지 1/1
    • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
    • Pry up from beneath the wires.
  8. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 8 단계, 이미지 1/2 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 8 단계, 이미지 2/2
    • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
    • Lift the cover off the logic board and set it aside.
  9. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 9 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
  10. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 10 단계, 이미지 1/2 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 10 단계, 이미지 2/2
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
  11. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 11 단계, 이미지 1/1
    • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
  12. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 12 단계, 이미지 1/2 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 12 단계, 이미지 2/2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  13. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 13 단계, 이미지 1/2 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 13 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Be sure you are flipping up the hinged retaining flap, not the socket itself.
    • Pull the keyboard backlight ribbon cable out of its socket.
  14. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 14 단계, 이미지 1/1
    • Remove the following nine screws:
    • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
    • Two 8 mm T6 Torx screws on the DC-In board
  15. MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 1/3 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 2/3 MacBook Pro 15" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 3/3
    • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
    • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
    • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,638 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Should a person be using an ESD wristband or anti-static mat when doing this? I didn’t use one and now I’m worried.
Nick Doe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,749
