부품
지정된 부품이 없습니다.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
Lift the right fan out of its opening in the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
Lift the cover off the logic board and set it aside.
Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Remove the following nine screws:
Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
Two 8 mm T6 Torx screws on the DC-In board
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
