주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Late 2008 and Early 2009 Access Door Replacement
필요한 것
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Access Door Replacement, Access Door: 1 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Access Door Replacement, Access Door: 1 단계, 이미지 2/2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Access Door Replacement: 2 단계, 이미지 1/1
    • The access door should now be raised enough to lift it up and out of the Unibody.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 31,223
