소개
Replacing a defective fan is pretty easy and will keep your laptop running cool. This guide is for the fan on the right side of the Macbook when in normal operation. It will be the left-hand fan when you are removing it.
필요한 것
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
No. You do not need to charge it completely before removing it.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
Using both hands, lift and remove the lower case off the upper case.
About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
Use a spudger to pry the fan connector straight up and out of its socket on the logic board.
Did it the way described. Maybe because of the age of the Mac/circuit board but the sockets came out with the connector. Only solution now for this fan to work would be to hard solder. Not a happy outcome.
Remove the following three screws securing the right fan to the upper case and logic board:
Two 3.2 mm Phillips screws.
One 3.5 mm Phillips screw.
I ruined the head of the heads of the 3.2 mm and the 3.5 Phillips screws. What kind of screws are this (M1, M1.2, ...?)? I need a replacement.
PS I used the appropriate screw driver (Wiha PH00).
Hi! how did you fix it? I ruined the last two red 3,2 mm screws as well, so the old fan is still in there....
I can't seem to get the two (2) 3.2 screws out, they are in way too tight. I'm afraid of rounding out the slots and putting too much pressure on the board. No issues with replacing the other fan..any hints/tricks to getting these screws out? thanks
Same problem here, killed the head of the top left 3.2 mm screw … any ideas how to get it out now?
I have been reading this so many times …
“”killed the head screws “”
May I suggest , open your laptop at L shape
Upside down keyboard on your desk but your screen vertical out the way !
And doing a little more pressure with out rush very gently breaking loctite paint ….
Good luck guys 🤙🏻
다른 71명이 해당 안내서를 완성하였습니다.
댓글 한 개
A great walkthrough.
Once completed, I did a reset of the PRAM, and it all worked beautifully.
Thanks again.
The A1286 has no Access Door.!!
I actually can see no sign of the battery!...
aguib - 답글
I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
lgc90 - 답글
when will there be a guide for the other unibody macbook pro. that does not have an access door?
irishking - 답글
Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
Max
Max - 답글
On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
Can you confirm this?
Many thanks in advance.
ahothabeth - 답글
My display and aluminum casing has separated.
I don't know if it just snaps back together or does it need to be glued.
I dropped mine on the carpeted stairs and the display still works.
I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
portion have been broken........
SHerwood Ball - 답글
When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
thvv - 답글
We always use left and right in reference to the computer when you're using it.
Andrew Optimus Goldheart -
Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
Thanks for the directions ...could not have done it with out them!!!
landryd - 답글
Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
jegonzalez80 - 답글
Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
kenneth krabat - 답글
