이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace a faulty fan to keep temperatures down.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
다른 38명이 해당 안내서를 완성하였습니다.
댓글 2개
Rosario, take that to a pro. Those things sometimes can be resoldered (Glue wont work), but it takes an experts eye and a steady hand. I got that eye, I dont have the hand, so as much as I can drive an oscilloscope with the best of them, my hand tremmor means I’d never trust a fix like that to myself.
