소개
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
다른 115명이 해당 안내서를 완성하였습니다.
댓글 3개
There's a visual of the screw configuration on the apple support website:
Great tutorial, but I think moderate might be a bit of an understatement; this project took me roughly five minutes, and I’ve never taken apart a computer before.
