주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement
필요한 것
  1. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Optical Drive: 5 단계, 이미지 1개 중 1개
    • Disconnect the camera cable connector from its socket on the logic board.
    • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
  6. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  7. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
  8. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Remove following two screws:
    • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  9. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
  10. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
  11. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: 11 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
    • Peel the hard drive cable up from the channel within the subwoofer and right speaker.
  12. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 12 단계, 이미지 1개 중 1개
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  13. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the following six screws securing the subwoofer and right speaker to the upper case:
    • Two 3.2 mm Phillips screws.
    • Two 12.3 mm Phillips screws.
    • One 2.5 mm Phillips screw.
    • One 8.3 mm Phillips screw.
  14. MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 14 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Late 2011 Subwoofer & Right Speaker Replacement: 14 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to dislodge the right speaker from its recess in the upper case.
    • Lift the subwoofer and right speaker assembly out of the upper case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Miroslav Djuric
160,503 평판
안내서 144개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 45
전체 시간: 9,759
