주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
  2. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 2 단계, 이미지 1/2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
  3. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Peel the camera cable off the adhesive securing it to the optical drive.
  4. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 4 단계, 이미지 1/2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 4 단계, 이미지 2/2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  5. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 5 단계, 이미지 1/2 MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  6. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  7. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 7 단계, 이미지 1/1
    • Remove the single 3.5 mm Phillips screw securing the inner side of the optical drive to the upper case.
  8. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 8 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips screws securing the outer side of the optical drive to the upper case.
  9. MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement: 9 단계, 이미지 1/1
    • Lift the optical drive from its left edge and pull it out of the upper case.
결론
Andrew Bookholt
586,022 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 783
