주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement
필요한 것
  1. MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement, Lower Case: 1 단계, 이미지 1/1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement: 2 단계, 이미지 1/1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 한 개
When replacing the lower case, be sure to re-seat the clips that popped when removing it. There are two, located near the edge of the battery and the motherboard. Apply firm pressure over these spots until the clips click again, before replacing the screws.
keithbartholomew - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 9
30일 전: 24
전체 시간: 40,994
