소개
Replacing a defective fan is pretty easy and will keep your laptop running cool.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove three T6 Torx screws securing the right fan to the logic board and upper case.
거의 끝나갑니다!
결론
다른 58명이 해당 안내서를 완성하였습니다.
