소개
Replace the broken feet for your mid 2012 15" MacBook Pro.
필요한 것
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Align the new foot inside the foot pad.
Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
다른 19명이 해당 안내서를 완성하였습니다.
