주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement
필요한 것
  1. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Right Fan: 5 단계, 이미지 3개 중 1개 MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Right Fan: 5 단계, 이미지 3개 중 2개 MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement, Right Fan: 5 단계, 이미지 3개 중 3개
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  7. MacBook Pro 15" Unibody Mid 2012 Right Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the right fan out of the upper case.
결론
다른 31명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
512,215 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,610개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 31
전체 시간: 11,311
