주요 콘텐츠로 건너뛰기
MacBook Pro 16" 2019 Speaker Replacement
필요한 것
동영상 개요
  1. MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: 1 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Open the Macbook: 1 단계, 이미지 2개 중 2개
    • First step is opening up the MacBook. This was the most challenging step and maybe because it got me by surprise. The process works a bit different then older MacBooks. Watch this video if you are not aware of the process: https://www.youtube.com/watch?v=mHutSzIk...
    • Hint - Try pulling the bottom cover forward.
  2. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: 2 단계, 이미지 3개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: 2 단계, 이미지 3개 중 2개 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the battery: 2 단계, 이미지 3개 중 3개
    • After opening up, disconnect the battery. Remove the cable and take out the big screw; this is to make sure there is no power running through.
  3. MacBook Pro 16" 2019 Speaker Replacement, The part: 3 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, The part: 3 단계, 이미지 2개 중 2개
    • I'm going to replace the left and right speaker. I bought a few on AliExpress, since they were sold out on iFixit, however they arrived damaged. Hopefully they work.
  4. MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: 4 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Disconnect the speaker: 4 단계, 이미지 2개 중 2개
    • On both sides, open up the connector and take out the cable.
  5. MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: 5 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Remove the Speaker: 5 단계, 이미지 2개 중 2개
    • Taking out the speaker is where it gets sketchy. It's hanging in there with VERY strong adhesive. Luckily, I'm going to replace the speakers and am not going to keep them so I can be rough. If you want to keep the speaker, I would advise another approach.
  6. MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: 6 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Take out the other side: 6 단계, 이미지 2개 중 2개
    • Same story on the other side. Wiggle your tool underneath and force it out.
  7. MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: 7 단계, 이미지 2개 중 1개 MacBook Pro 16" 2019 Speaker Replacement, Remove the adhesive: 7 단계, 이미지 2개 중 2개
    • Removing the adhesive and pulling it out is easy. If you can't pull it out, use a tool to carefully scratch it off the surface.
  8. MacBook Pro 16" 2019 Speaker Replacement, Clean the adhesive: 8 단계, 이미지 1개 중 1개
    • When cleaning the leftover adhesive, it's best to use an alcohol pad to clean it up as well as the general area.
    • Let the area dry before installing the speaker.
  9. MacBook Pro 16" 2019 Speaker Replacement, Ready for replacing: 9 단계, 이미지 1개 중 1개
    • After removing both speakers, your MacBook should look like the one in the photo.
    • If you cleaned off adhesive in the previous step, make sure the area is clean/dry before moving on.
  10. MacBook Pro 16" 2019 Speaker Replacement, Glue: 10 단계, 이미지 1개 중 1개
    • This step is optional if your replacement speaker does not have any adhesive.
    • Put adhesive around the outside of the speaker; use the glue sparingly.
    • Make sure you are using a glue that is specifically designed for computer repair or speaker repair. Here is a solvent that can be used for this guide.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Dave Hakkens
회원 가입일: 01/03/16
1,042 평판
안내서 3개를 작성함
11가이드 댓글
I just created an account to thank you,
I bought the speakers from ifix it, and I did follow your guide, and it worked perfectly.
so I joined here to thank you.
your guide helped me a lot. I appreciate the effort.
ALAA ALMAATOUQ - 답글
appreciate that. Happy to hear its useful :)
Dave Hakkens -
This was very helpful... I managed to successfully replace mine... but unfortunately on step 5 I made the mistake of scuffing the battery, revealing the aluminum layer inside and it gave off a sweet smell (which i now understand is dangerous)
Painfully had to have the battery replaced for about 300$ (I'm in Nairobi, Kenya)
Maybe update the steps to avoid the nearby battery which is really sensitive.
Cheers
leemalu - 답글
Thank you for this! I broke my speaker when following a different iFixIt guide, but your instructions saved the day. $49 is even for the replacement speaker from iFixIt is even cheaper than the deductible on my insurance plan through GetAkko, so this one was a no-brainer. Thank you, internet stranger!
Peter - 답글
What are the tools that I’ll need to do this? Are they available on iFixit? Thank you!
[deleted] - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 155
지난 30일: 701
전체 시간: 20,503
