주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 16" 2021 Logic Board Replacement
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.1 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 16" 2021 Logic Board Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unclip the lower case: 2 단계, 이미지 2개 중 2개
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's right clips: 3 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's right clips: 3 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's right clips: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's left clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's left clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Release the rear cover's left clips: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 16" 2021 Logic Board Replacement: 5 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 5 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement: 5 단계, 이미지 3개 중 3개
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  6. MacBook Pro 16" 2021 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the lower case: 6 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  7. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery board: 7 단계, 이미지 3개 중 3개
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 16" 2021 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 16" 2021 Logic Board Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the trackpad cable bracket: 10 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 16" 2021 Logic Board Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the trackpad cable bracket: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the trackpad cable: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 16" 2021 Logic Board Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Reposition the trackpad cable: 13 단계, 이미지 2개 중 2개
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery board: 14 단계, 이미지 2개 중 2개
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 16" 2021 Logic Board Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 15 단계, 이미지 2개 중 2개
  16. MacBook Pro 16" 2021 Logic Board Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 16 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 16" 2021 Logic Board Replacement, Remove the data cable: 17 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the data cable: 17 단계, 이미지 2개 중 2개
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the battery connector: 18 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery power connector.
  19. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery connector: 19 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the battery connector: 19 단계, 이미지 2개 중 2개
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
  20. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the antenna bar's connector bracket: 20 단계, 이미지 2개 중 2개
    • Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 16" 2021 Logic Board Replacement: 21 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 21 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the antenna bar: 22 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the display cable covers: 23 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the display cable covers: 23 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the display cable covers.
  24. MacBook Pro 16" 2021 Logic Board Replacement, Remove the display cable covers: 24 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the display cable covers: 24 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the two display cable covers from the logic board.
  25. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the display cables: 25 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the display cables: 25 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the display cables: 25 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the two right-most display cable press connectors secured to the logic board.
  26. MacBook Pro 16" 2021 Logic Board Replacement: 26 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 26 단계, 이미지 2개 중 2개
    • Repeat the previous disconnection process for the remaining press connector.
  27. MacBook Pro 16" 2021 Logic Board Replacement: 27 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 27 단계, 이미지 2개 중 2개
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 16" 2021 Logic Board Replacement: 28 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 28 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 16" 2021 Logic Board Replacement: 29 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 29 단계, 이미지 2개 중 2개
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the right-side cable covers: 30 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the right-side cable covers: 30 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the 11 screws securing the right cable covers to the frame:
    • Nine 2.1 mm screws
    • One 2 mm screw
    • One 3.5 mm screw
  31. MacBook Pro 16" 2021 Logic Board Replacement, Remove the right cable covers: 31 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the right cable covers: 31 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the right speaker: 32 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the right speaker: 32 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the right speaker's press connector.
  33. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the headphone jack: 33 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the headphone jack: 33 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  34. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the right USB-C ports: 34 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the right USB-C ports: 34 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the right USB-C ports: 34 단계, 이미지 3개 중 3개
    • Use a spudger to pry up and disconnect the right USB-C ports' two press connectors.
  35. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the MagSafe port: 35 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the MagSafe port: 35 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  36. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the lid angle sensor cable: 36 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the lid angle sensor cable: 36 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  37. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the left cable covers: 37 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the left cable covers: 37 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the six screws securing the left cable covers to the frame:
    • Four 2.1 mm screws
    • One 2 mm screw
    • One 3.6 mm screw
  38. MacBook Pro 16" 2021 Logic Board Replacement, Remove the left cable covers: 38 단계, 이미지 1개 중 1개
    • Use tweezers, or your fingers, to remove the three left cable covers.
  39. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the left speaker: 39 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the left speaker: 39 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the left speaker's press connector.
  40. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the left USB-C port: 40 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the left USB-C port: 40 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  41. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the Touch ID sensor: 41 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the Touch ID sensor: 41 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector.
  42. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the keyboard: 42 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the keyboard: 42 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the keyboard: 42 단계, 이미지 3개 중 3개
  43. MacBook Pro 16" 2021 Logic Board Replacement: 43 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 43 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement: 43 단계, 이미지 3개 중 3개
    • Use a spudger to gently pry up the locking flap on the two ZIF connectors for the keyboard cables.
  44. MacBook Pro 16" 2021 Logic Board Replacement: 44 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 44 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement: 44 단계, 이미지 3개 중 3개
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  45. MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the fans: 45 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the fans: 45 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Disconnect the fans: 45 단계, 이미지 3개 중 3개
    • Peel back any tape covering the right fan cable connector.
  46. MacBook Pro 16" 2021 Logic Board Replacement: 46 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 46 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  47. MacBook Pro 16" 2021 Logic Board Replacement: 47 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 47 단계, 이미지 2개 중 2개
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  48. MacBook Pro 16" 2021 Logic Board Replacement, Reposition the right fan cable: 48 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Reposition the right fan cable: 48 단계, 이미지 2개 중 2개
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  49. MacBook Pro 16" 2021 Logic Board Replacement: 49 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 49 단계, 이미지 2개 중 2개
    • Repeat the previous disconnection and reposition procedure for the left fan cable.
  50. MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the logic board: 50 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Unfasten the logic board: 50 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the ten screws securing the logic board to the frame:
    • Six 3.8 mm screws
    • Four 4.6 mm screws
    • Use a 4 mm Hex nut driver to remove the two 6 mm screws securing the logic board to the frame.
    • Use a T6 Torx driver to remove the two 6 mm screws securing the heat sink to the logic board and frame.
  51. MacBook Pro 16" 2021 Logic Board Replacement, Release the logic board's clips: 51 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Release the logic board's clips: 51 단계, 이미지 2개 중 2개
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
  52. MacBook Pro 16" 2021 Logic Board Replacement: 52 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement: 52 단계, 이미지 2개 중 2개
    • Insert a spudger between the bottom of the logic board and the frame.
  53. MacBook Pro 16" 2021 Logic Board Replacement, Remove the logic board: 53 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the logic board: 53 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Remove the logic board: 53 단계, 이미지 3개 중 3개
    • Gently lift up the logic board by its right side to completely release the clips.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  54. MacBook Pro 16" 2021 Logic Board Replacement, Reassembly information: 54 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Logic Board Replacement, Reassembly information: 54 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Logic Board Replacement, Reassembly information: 54 단계, 이미지 3개 중 3개
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
    • Make sure all of the connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
236,276 평판
안내서 1,168개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,536개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 27
전체 시간: 365
