주요 콘텐츠로 건너뛰기
MacBook Pro 16" Late 2023 Antenna Bar Replacement
필요한 것
  1. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 3개
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the lower case: 2 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the lower case: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.2 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unclip the lower case: 3 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unclip the lower case: 3 단계, 이미지 2개 중 2개
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  4. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the lower case's right clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the lower case's right clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the lower case's right clips: 4 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the rear cover's left clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the rear cover's left clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the rear cover's left clips: 5 단계, 이미지 3개 중 3개
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 3개
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  7. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the lower case: 7 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the lower case: 7 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the lower case: 7 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the screen hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  8. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery board: 8 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery board: 8 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery board: 8 단계, 이미지 3개 중 3개
    • Peel back any tape covering the battery board data cable connector on the logic board.
  9. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  10. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  11. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the trackpad cable bracket: 11 단계, 이미지 1개 중 1개
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  12. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the trackpad cable bracket: 12 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the trackpad cable bracket: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  13. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the trackpad cable: 13 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the trackpad cable: 13 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Reposition the trackpad cable: 14 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Reposition the trackpad cable: 14 단계, 이미지 2개 중 2개
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  15. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery board: 15 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery board: 15 단계, 이미지 2개 중 2개
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  16. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 16 단계, 이미지 2개 중 2개
  17. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 17 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  18. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the data cable: 18 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the data cable: 18 단계, 이미지 2개 중 2개
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  19. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the battery connector: 19 단계, 이미지 1개 중 1개
    • Use a 5IP Torx Plus driver to remove the 4 mm pancake screw securing the battery power connector.
  20. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery connector: 20 단계, 이미지 3개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery connector: 20 단계, 이미지 3개 중 2개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the battery connector: 20 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  21. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the antenna bar's connector bracket: 21 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the antenna bar's connector bracket: 21 단계, 이미지 2개 중 2개
    • Use a 3IP Torx Plus screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  22. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 22 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 22 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  23. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the antenna bar: 23 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Disconnect the antenna bar: 23 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  24. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the antenna bar: 24 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Unfasten the antenna bar: 24 단계, 이미지 2개 중 2개
    • Use a 5IP Torx Plus screwdriver to remove the six screws securing the antenna bar to the frame:
    • Two 7.5 mm screws
    • Four 3 mm screws
    • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
    • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
  25. MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the antenna bar: 25 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement, Remove the antenna bar: 25 단계, 이미지 2개 중 2개
    • Insert the tip of a spudger between the antenna bar and the frame.
    • Pry up with the spudger to separate the antenna bar from the frame.
  26. MacBook Pro 16" Late 2023 Antenna Bar Replacement: 26 단계, 이미지 2개 중 1개 MacBook Pro 16" Late 2023 Antenna Bar Replacement: 26 단계, 이미지 2개 중 2개
    • Pull the antenna bar straight up and out of the frame to remove it.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" Late 2023 Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,011 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,619개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 74
전체 시간: 1,571
