주요 콘텐츠로 건너뛰기
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, Battery: 1 단계, 이미지 1/1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, RAM Shield: 2 단계, 이미지 1/1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 3 단계, 이미지 1/1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, Upper Case: 4 단계, 이미지 1/1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 5 단계, 이미지 1/1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 6 단계, 이미지 1/1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 7 단계, 이미지 1/1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 8 단계, 이미지 1/1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 9 단계, 이미지 1/1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 10 단계, 이미지 1/1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, AirPort Extreme: 11 단계, 이미지 1/3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, AirPort Extreme: 11 단계, 이미지 2/3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement, AirPort Extreme: 11 단계, 이미지 3/3
    • Disconnect the two antenna cables attached to the AirPort Extreme card.
    • The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
    • If you have a MacBook Pro 17" Model A1229 or A1212, there are three antenna cables attached to the AirPort Extreme card instead of two.
    • If you have a MacBook Pro 17” Model A1261 the cable with the black shielding attaches to the left side of the connector, while the cable with blue shielding attaches to the right side.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 12 단계, 이미지 1/1
    • Remove the single black T6 Torx screw from the top right corner of the AirPort Extreme card.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme Replacement: 13 단계, 이미지 1/1
    • Lift the AirPort Extreme card up and slide it out of its connector.
    • Note the position of the grounding clip attached to the left side of the card. On some models, the clip is mounted on the upper surface of the airport Extreme card to make contact with the upper case. On other models, the clip is mounted on the underside and makes contact with the headphone connector body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 8,766
