주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide is an internal prerequisite.
  1. Use the flat end of a spudger to carefully peel off the three antenna straps stuck to the lower edge of the LCD.
    • Use the flat end of a spudger to carefully peel off the three antenna straps stuck to the lower edge of the LCD.
  2. Remove the five Phillips screws securing the clutch cover to the bottom edge of the front display bezel.
    • Remove the five Phillips screws securing the clutch cover to the bottom edge of the front display bezel.
  3. Remove the two pieces of tape securing the display data cable to the LCD. Remove the two pieces of tape securing the display data cable to the LCD.
    • Remove the two pieces of tape securing the display data cable to the LCD.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Disconnect the display data cable from the LCD by pulling it toward the bottom edge of the display. Disconnect the display data cable from the LCD by pulling it toward the bottom edge of the display.
    • Disconnect the display data cable from the LCD by pulling it toward the bottom edge of the display.
  6. Move the display data cable out of the way to remove the Phillips screw hidden underneath.
    • Move the display data cable out of the way to remove the Phillips screw hidden underneath.
  7. While pulling the clutch assembly away from the clutch hinge with one hand, insert an iPod opening tool between the clutch cover and the front display bezel to lift the clutch cover over the retaining pin on the front display bezel. Pull the clutch assembly away from the front display bezel.
    • While pulling the clutch assembly away from the clutch hinge with one hand, insert an iPod opening tool between the clutch cover and the front display bezel to lift the clutch cover over the retaining pin on the front display bezel.
    • Pull the clutch assembly away from the front display bezel.
  8. Repeat the process covered in the previous step to free the other side of the clutch assembly from the front display bezel.
    • Repeat the process covered in the previous step to free the other side of the clutch assembly from the front display bezel.
  9. Remove the clutch assembly from the front display bezel, minding any cables that may get caught.
    • Remove the clutch assembly from the front display bezel, minding any cables that may get caught.
결론
Andrew Bookholt
545,744 평판
안내서 618개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,070
