이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
필요한 것
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. Be careful to slide the connectors as they may become damaged otherwise.
Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
다른 45명이 해당 안내서를 완성하였습니다.
댓글 3개
Does any one know what the pinout is on the display connector. I am assuming that the first 4 fairly spaced out pins are power. We got a working display form a broken A1229 and are planning to use the display for our experimental purposes. Before doing that we need to know if the display is any good.
thanks
This is my first action with a used Apple laptop A1229. I’m a Vet, Army ‘72-’75 & worked/volunteered about 30 years helping ther Vets and families along with employers match up. My “frustration” as a newbie, is which way to move the pins, up, out, lift, don’t, etc. Would be nice to have close up pics of the ends and see some arrows or descriptors telling me what to do w/o damage. I bumped a short wire that rested w/sensor of some kind on top of MB and detached it, oh well. Trying to get screen to my wife’s laptop, then remove this logic board & hope it works and install into my used A1229 17” Mac Pro. Hoping to save up and purchase a used quad core 17” but time will tell. Thanks to all of you who are putting ut info, helps folks like me.
I hate the screen replacement.
