소개
This connects the left I/O board to the logic board.
필요한 것
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the hard drive ribbon cable and the left I/O board ribbon cable from the logic board.
Disconnect the right speaker connector from the left I/O board.
다른 4명이 해당 안내서를 완성하였습니다.
