소개
Removing a few screws will remove this part and allow access to your RAM.
필요한 것
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
거의 끝나갑니다!
결론
다른 9명이 해당 안내서를 완성하였습니다.
