주요 콘텐츠로 건너뛰기
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement
필요한 것
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Battery: 1 단계, 이미지 1/1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, RAM Shield: 2 단계, 이미지 1/1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 3 단계, 이미지 1/1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Upper Case: 4 단계, 이미지 1/1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 5 단계, 이미지 1/1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 6 단계, 이미지 1/1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 7 단계, 이미지 1/1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 8 단계, 이미지 1/1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 9 단계, 이미지 1/1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 10 단계, 이미지 1/1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Right Fan: 11 단계, 이미지 1/2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Right Fan: 11 단계, 이미지 2/2
    • Disconnect the display data cable and right fan cable from the logic board.
    • If you have a MacBook Pro 17" Model A1229 or A1212, the connectors have different compositions and are highlighted in the second picture.
    • For models A1229 and/or A1212, carefully wedge the flat end of a spudger underneath the right fan cable to pry it up off its socket. Failure to do so may result in the whole socket coming off the motherboard instead of just the cable.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 12 단계, 이미지 1/1
    • Remove the three silver T6 Torx screws securing the right fan.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 13 단계, 이미지 1/1
    • Lift the right fan and its metal bracket out of the logic board.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Right Thermal Sensor: 14 단계, 이미지 1/2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement, Right Thermal Sensor: 14 단계, 이미지 2/2
    • Disconnect the right thermal sensor cable from the logic board.
    • If you have the A1261 model, the right thermal sensor cable is located in between the right fan connector and display data cable.
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Thermal Sensor Replacement: 15 단계, 이미지 1/1
    • Peel up the orange Kapton tape covering the right thermal sensor.
    • Use a spudger to pry the right thermal sensor off the lower case.
결론
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 9,433
