주요 콘텐츠로 건너뛰기
MacBook Pro 17" Unibody fixing noise fan and overheat
필요한 것
  1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Before starting: 1 단계, 이미지 1/1
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Getting ready: 2 단계, 이미지 1/1
    • Turn your MBP upside down
  3. MacBook Pro 17" Unibody  fixing noise fan and overheat, Screws first: 3 단계, 이미지 1/1
    • Remove the screws from the back cover
  4. MacBook Pro 17" Unibody  fixing noise fan and overheat, Open it !: 4 단계, 이미지 1/1
    • Carefully open the back cover.
  5. MacBook Pro 17" Unibody  fixing noise fan and overheat, Dust ? No, thanks !: 5 단계, 이미지 1/1
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. MacBook Pro 17" Unibody  fixing noise fan and overheat, Apple warranty: 6 단계, 이미지 1/1
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 7 단계, 이미지 1/3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 7 단계, 이미지 2/3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: 7 단계, 이미지 3/3
    • Disconnect the fan from the mainboard.
  8. MacBook Pro 17" Unibody  fixing noise fan and overheat, Almost there !: 8 단계, 이미지 1/1
    • Remove the 3 screws that fron the fan fixture.
  9. MacBook Pro 17" Unibody  fixing noise fan and overheat, Take a walk on the wild side !: 9 단계, 이미지 1/1
    • Clean the dust with a very soft toilet paper.
  10. MacBook Pro 17" Unibody  fixing noise fan and overheat, Finally!: 10 단계, 이미지 1/1
    • This is what I´ve found inside one fan !
결론
다른 12명이 해당 안내서를 완성하였습니다.
LAOMUSIC ARTS
회원 가입일: 02/25/17
589 평판
안내서 1개 작성함
댓글 6개
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - 답글
Thanks a lot s
Sanzi Gao - 답글
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - 답글
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - 답글
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Eric Hammond - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 74
전체 시간: 9,584
