If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
