이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
Remove the two 2.2 mm Phillips screws securing the Bluetooth housing to the side of the optical drive.
De-route the camera cable from its slot in the Bluetooth housing and remove the Bluetooth board from the upper case.
다른 6명이 해당 안내서를 완성하였습니다.
