주요 콘텐츠로 건너뛰기
MacBook Pro 17" Unibody Hard Drive Cable Replacement
필요한 것
  1. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 2 단계, 이미지 2개 중 1개 MacBook Pro 17" Unibody Hard Drive Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 3 단계, 이미지 3개 중 1개 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 3 단계, 이미지 3개 중 2개 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 7 단계, 이미지 2개 중 1개 MacBook Pro 17" Unibody Hard Drive Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: 8 단계, 이미지 2개 중 1개 MacBook Pro 17" Unibody Hard Drive Cable Replacement, Hard Drive Cable: 8 단계, 이미지 2개 중 2개
    • Remove the following four screws securing the hard drive cable assembly to the upper case:
    • Two 1.6 mm Phillips screws securing the shield that covers the hard drive cable connector.
    • Two 2.2 mm Phillips screws securing the hard drive cable connector to the upper case.
    • Remove the shield from the logic board.
  9. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 9 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the hard drive connector up and out of its socket on the logic board.
  10. MacBook Pro 17" Unibody Hard Drive Cable Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the hard drive cable out of the upper case.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Bookholt
596,132 평판
안내서 619개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 20,697
