이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
If present, remove the small piece of EMI foam near the Bluetooth board.
De-route the camera cable from the slot molded into the Bluetooth board housing.
Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
Remove the optical drive from the upper case, minding any cables that may get caught.
