주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
MacBook Pro Retina 2012–2015 Feet Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro Retina 2012–2015 Feet Replacement, Feet: 1 단계, 이미지 1/2 MacBook Pro Retina 2012–2015 Feet Replacement, Feet: 1 단계, 이미지 2/2
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  2. MacBook Pro Retina 2012–2015 Feet Replacement: 2 단계, 이미지 1/2 MacBook Pro Retina 2012–2015 Feet Replacement: 2 단계, 이미지 2/2
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  3. MacBook Pro Retina 2012–2015 Feet Replacement: 3 단계, 이미지 1/1
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  4. MacBook Pro Retina 2012–2015 Feet Replacement: 4 단계, 이미지 1/1
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  5. MacBook Pro Retina 2012–2015 Feet Replacement: 5 단계, 이미지 1/1
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  6. MacBook Pro Retina 2012–2015 Feet Replacement: 6 단계, 이미지 1/3 MacBook Pro Retina 2012–2015 Feet Replacement: 6 단계, 이미지 2/3 MacBook Pro Retina 2012–2015 Feet Replacement: 6 단계, 이미지 3/3
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  7. MacBook Pro Retina 2012–2015 Feet Replacement: 7 단계, 이미지 1/2 MacBook Pro Retina 2012–2015 Feet Replacement: 7 단계, 이미지 2/2
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Taylor Dixon
회원 가입일: 06/26/18
67,089 평판
안내서 94개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,118
