소개
Remove the clutch cover to access cables terminating inside the display.
필요한 것
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the single 3 mm Phillips screw securing the AirPort/Bluetooth antenna ground strap to the rear speaker.
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
다른 13명이 해당 안내서를 완성하였습니다.
2 댓글
Plz plz if you explain how to fix any devices from first plz end it to close again , because some devices unable to close like apple wireless keyboard when i try to open ok good put when i try to close it not good .
and plz make to every process video because some process not Clear
" thx for understand" and very good work .
The white screen gasket (trim) on my MacBook A1342 is peeling off. How do I insert it back? It keeps peeling back off even when I insert it back. It only happens at one specific spot. I don't want to replace the trim. I just want to glue it back in. What kind of glue may I use?
Dario Meze - 답글
