소개
Removing a white Unibody MacBook disk drive and RAM.
필요한 것
After removing the screws and plastic cover piece, remove the hard drive then unplug from Logic Board.
Locate the RAM Directly above the Hard Drive. Gently push the two snaps away from the RAM cards and gently pull the ram out. You Will do this step again to remove the Second card beneath the first.
다른 12명이 해당 안내서를 완성하였습니다.
