주요 콘텐츠로 건너뛰기
Macbook Pro 14" Early 2023 Trackpad Without Cable Removal
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Unfasten the trackpad: 1 단계, 이미지 2개 중 1개 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Unfasten the trackpad: 1 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the ten 5.7 mm screws securing the trackpad assembly:
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  2. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: 2 단계, 이미지 3개 중 1개 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: 2 단계, 이미지 3개 중 2개 Macbook Pro 14" Early 2023 Trackpad Without Cable Removal, Remove the trackpad: 2 단계, 이미지 3개 중 3개
    • Swing the screen open slightly, but keep the MacBook upside-down. The trackpad should separate and lay flat on the display.
    • As you remove the trackpad, be very careful not to lose the six small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  3. Macbook Pro 14" Early 2023 Trackpad Without Cable Removal: 3 단계, 이미지 1개 중 1개
    • Remove the trackpad.
    • During reassembly, make sure that each of the nine washers are present before you install the trackpad.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,038 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 60
