주요 콘텐츠로 건너뛰기
Macintosh IIsi Hard Drive Replacement
필요한 것
  1. Macintosh IIsi Hard Drive Replacement, Top Case: 1 단계, 이미지 2개 중 1개 Macintosh IIsi Hard Drive Replacement, Top Case: 1 단계, 이미지 2개 중 2개
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 1개 Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 2개 Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 3개
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
37,656 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 2개
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - 답글
Is there a way to read the HDD on a PC?
Charles - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 4
지난 30일: 6
전체 시간: 4,057
