주요 콘텐츠로 건너뛰기
Macintosh IIsi Hard Drive Replacement
필요한 것
  1. Macintosh IIsi Hard Drive Replacement, Top Case: 1 단계, 이미지 1/2 Macintosh IIsi Hard Drive Replacement, Top Case: 1 단계, 이미지 2/2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 1/3 Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 2/3 Macintosh IIsi Hard Drive Replacement: 2 단계, 이미지 3/3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Macintosh IIsi Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 1/3 Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 2/3 Macintosh IIsi Hard Drive Replacement: 4 단계, 이미지 3/3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
    How can a read that SCSI HDD today if the computer does not boot? Any way to connect externally to a PC?
    Charles - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
36,978 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 2개
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - 답글
Is there a way to read the HDD on a PC?
Charles - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 3,947
