주요 콘텐츠로 건너뛰기
Macintosh IIsi Ram Replacement
필요한 것
  1. Macintosh IIsi Ram Replacement, Top Case: 1 단계, 이미지 1/2 Macintosh IIsi Ram Replacement, Top Case: 1 단계, 이미지 2/2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Ram Replacement: 2 단계, 이미지 1/3 Macintosh IIsi Ram Replacement: 2 단계, 이미지 2/3 Macintosh IIsi Ram Replacement: 2 단계, 이미지 3/3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Ram Replacement, Ram: 3 단계, 이미지 1/3 Macintosh IIsi Ram Replacement, Ram: 3 단계, 이미지 2/3 Macintosh IIsi Ram Replacement, Ram: 3 단계, 이미지 3/3
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  4. Macintosh IIsi Ram Replacement: 4 단계, 이미지 1/3 Macintosh IIsi Ram Replacement: 4 단계, 이미지 2/3 Macintosh IIsi Ram Replacement: 4 단계, 이미지 3/3
    • 1st Photo: The RAM Module
결론
다른 4명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
37,026 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 2,231
