주요 콘텐츠로 건너뛰기
Macintosh PowerBook 1400 Series Hard Drive Replacement
필요한 것
  1. Macintosh PowerBook 1400 Series Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Hard Drive Replacement, CD-ROM Drive: 4 단계, 이미지 1개 중 1개
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Hard Drive Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Hard Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Hard Drive Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Hard Drive Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Hard Drive Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Hard Drive Replacement: 17 단계, 이미지 1개 중 1개
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Hard Drive Replacement: 18 단계, 이미지 1개 중 1개
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Hard Drive Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the keyboard.
  20. Macintosh PowerBook 1400 Series Hard Drive Replacement, Hard Drive: 20 단계, 이미지 1개 중 1개
    • Locate and identify the two screws that attach the hard drive to the computer.
  21. Macintosh PowerBook 1400 Series Hard Drive Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the screws with a Phillips #0 screwdriver.
  22. Macintosh PowerBook 1400 Series Hard Drive Replacement: 22 단계, 이미지 1개 중 1개
    • Once the screws are removed, lift up the end of the hard drive using your finger tips.
  23. Macintosh PowerBook 1400 Series Hard Drive Replacement: 23 단계, 이미지 1개 중 1개
    • Fully lift the hard drive vertically against the side of the computer.
  24. Macintosh PowerBook 1400 Series Hard Drive Replacement: 24 단계, 이미지 1개 중 1개
    • Push a finger down onto the plastic strap.
  25. Macintosh PowerBook 1400 Series Hard Drive Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Jeffrey Huntley
회원 가입일: 04/01/11
248 평판
안내서 1개를 작성함
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 회원
CPSU-FORTE-S11S10G39
5 회원들
안내서 6개를 작성함
1가이드 댓글
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
TB75 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 60
전체 시간: 9,595
