주요 콘텐츠로 건너뛰기
Macintosh PowerBook 1400 Series RAM Replacement
필요한 것
  1. Macintosh PowerBook 1400 Series RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series RAM Replacement, CD-ROM Drive: 4 단계, 이미지 1개 중 1개
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series RAM Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series RAM Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series RAM Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series RAM Replacement: 12 단계, 이미지 1개 중 1개
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series RAM Replacement: 13 단계, 이미지 1개 중 1개
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series RAM Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series RAM Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series RAM Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series RAM Replacement: 17 단계, 이미지 1개 중 1개
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series RAM Replacement: 18 단계, 이미지 1개 중 1개
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series RAM Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the keyboard.
  20. Macintosh PowerBook 1400 Series RAM Replacement, Memory (RAM): 20 단계, 이미지 1개 중 1개
    • Identify RAM Memory stick
    • These are the upgradeable RAM Memory sticks, they must be removed first
  21. Macintosh PowerBook 1400 Series RAM Replacement: 21 단계, 이미지 1개 중 1개
    • Gently grasp the ram on the far end as shown in the picture and then pull up and away from the right side of the computer
  22. Macintosh PowerBook 1400 Series RAM Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the upgradeable RAM stick
    • If the upgradeable RAM stick is all you are repairing you can end the guide here, however to remove the factory installed RAM please continue
  23. Macintosh PowerBook 1400 Series RAM Replacement: 23 단계, 이미지 1개 중 1개
    • Gently grasp the factory installed RAM by grabbing each end as shown in the picture and pull the stick directly up
  24. Macintosh PowerBook 1400 Series RAM Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the factory installed RAM memory module
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kian Dinyari
회원 가입일: 04/07/11
146 평판
안내서 1개를 작성함
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 회원
CPSU-FORTE-S11S10G39
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 4,639
